What we’re looking for as a Cable Assembler: Previous cable assembly experience within an electrical manufacturing environment... of expertise in designing and manufacturing high-quality electrical and cable assemblies, this privately-owned company...
required specifications. Carrying out basic cable and wiring assembly. Working from drawings, wiring information and assembly instructions... manufacturing, cable assembly, control panel production or a similar environment. What's on Offer £13.50 - £14.00 per hour...
for precision assembly. Requirements: HND / BTEC in electrical or electronics engineering, and demonstrable experience... sectors. They are looking for junior / experienced Hardware Assembly Technicians to put together prototypes and finished...
successful candidate will have hands-on experience in cable looming, internal wiring, soldering connectors, and electro-mechanical assembly... and assemble cable looms and wiring harnesses to engineering specifications. Carry out internal wiring of electrical and electro...
Electromechanical Assembly / Build Technicians Required West London About the Role A high-tech engineering company... is looking for temporary Electromechanical Assembly / Build Technicians required on a contract basis support an upcoming production...
at a modern facility, you will play a key role in the build and assembly of complex electrical and electro-mechanical systems... electrical schematics, wiring diagrams, assembly drawings and technical documentation. Carrying out point-to-point wiring...
and electrical assembly processes and providing specialist manufacturing skills related to this area. There are a wide range... cabinets, racks, frames and associated metalwork Manufacture of cable looms Printed circuit board assembly and repair...
such as a PC or other high-quality technical products. Wire looming, cable routing or cable assembly. Experience using mechanical...Mechanical Assembly Operator | Rochester, Kent | Competitive Salary + Overtime + Pension Join a specialist...
or equivalent. Desirable Previous workshop, manufacturing or assembly experience. Electrical/electronics or cable assembly..., components, heat-shrink and identification materials. Assist with cable, panel and mechanical assembly. Follow drawings, BOMs...
have: Strong electro-mechanical assembly experience. Good soldering, PCB, wiring and cable-harnessing skills. Experience...Electro-Mechanical Assembly Technician Woking, Surrey £27,000-£30,000 DOE An exciting opportunity has arisen...
